Topic: Scripting: relative events
ewewoHome userMember since 2018
Hi is it possible to script the duration of an autocrossfade bpm relative to 8 bars? instead of using seconds or miliseconds i want to use bars. maybe using "get _bpm" and divide the information?
geposted Wed 21 Nov 18 @ 12:25 pm
Automix can do it with automixSkipLength. That's meassured in beats and triggers when you force a mix in automix mode
Apart from that you may need to use the Builder plugin by Locodog
That is all about doing things "in time" - and I'm sure he can help you:
http://virtualdj.com/forums/224111/addons/Builder.html?page=1
geposted Wed 21 Nov 18 @ 1:13 pm
danke klaus!!!!!
geposted Wed 21 Nov 18 @ 3:12 pm
hey klaus, could you please explained detailed how automixSkipLength works?
geposted Wed 21 Nov 18 @ 8:15 pm
From memory:
If you are running in automix mode and force a premature mix to next song, - like by double clicking another track in the list - it's used to control the length of the mix
geposted Wed 21 Nov 18 @ 8:56 pm
