Topic: time code delay
so im using serato sl3 time code box, with a set of cdj, what i want to know is how can i fix the delay with these equipment ? i use virtual dj 8 pro infinite with a 2012 macbook pro
geposted Thu 22 Nov 18 @ 7:51 pm
A "set of cdj"? Please give more detail. Which CDJs? There are five current models, and about ten discontinued ones.
If you're using recent ones then you don't need timecode or the SL3 interface - the CDJs will connect directly to the computer and act as controllers and audio interfaces.
geposted Thu 22 Nov 18 @ 8:42 pm
