Hi,
Trying to map jog wheel on Hercules DJControl Starlight to scroll up/down in browser window when holding shift and turning jog wheel. I tried this on the SHIFT command and the SHIFT_JOG command but it doesn't work:
browser_window '$shift' while_pressed & deck left wheel_mode 'browser' while_pressed & deck right wheel_mode 'browser' while_pressed
Thanks in advance
Thanks in advance
geposted Thu 29 Nov 18 @ 1:46 am
Apparently you tried to remap your SHIFT button, right ?
The SHIFT button should be remapped to:
shift & set '$shift' while_pressed & deck left wheel_mode 'browser' while_pressed & deck right wheel_mode 'browser' while_pressed
The SHIFT_JOG element should not be altered
geposted Thu 29 Nov 18 @ 8:52 am
Thanks. Tried that but doesn't work. The script I provided works for the DJ Control Compact, if that helps.
geposted Fri 30 Nov 18 @ 7:52 pm
