Hey there,
Recently upgraded to the Pioneer DDJ SR2 and wanted to start introducing scratching into my mixes. Is it possible to map the mic level knob (I don't use a mic, or very rarely) so it changes the mix point of the crossfader i.e. shortening it for scratching and lengthening for when I don't want it?
Thanks in advance for your responses :)
geposted Tue 04 Dec 18 @ 4:02 am
I think the mic level on that unit is hardware based, so that it's simply analog, and doesn't send any midi signals to the laptop that can be picked up
But if you find a midi knob that you don't use, you can simply map it to:
crossfader_curve
If you just want to switch between full (the default) and scratch you can instead map a toggle between the two on a button or keyboard key, using a script like:
crossfader_curve 'full' ? crossfader_curve 'scratch' : crossfader_curve 'full'
There are also a few other ways to control the cross fader curve
Some are shown in this video:
crossfader_curve
geposted Tue 04 Dec 18 @ 10:22 am
I had a feeling that was the case!!
Thanks for the info though! I can feel a custom button coming on!!
Many thanks :)
Many thanks :)
geposted Wed 05 Dec 18 @ 1:01 am
