I used VDJ last Friday night for several hours with no issues. This week when I opened it up, it indicated that there was an update so I installed the update. Once it relaunched, each time I open the program it says that I have attached a new controller. I went in to Settings to get a new skin for the controller I'm using (Pioneer DDJ-SB2). When I select "Get More" under Main GUI skins VDJ crashes. (It's done this several times now)
I unplugged the controller and when I go into settings to change the Audio settings, VDJ crashes.
I've uninstalled, re-downloaded and re-installed. Same problem.
V8.3
b4675
V8.3
b4675
geposted Fri 07 Dec 18 @ 6:37 pm
You didn't go back to the previous build? If you think it was caused by the update, reinstall the previous version.
geposted Fri 07 Dec 18 @ 6:53 pm
This has been fixed in the current Early Access release. (4718)
geposted Fri 07 Dec 18 @ 6:55 pm
[/quote]
[/quote]
Pardon my ignorance... but how do you do that? Also, since I have now lost ALL my previous settings and lists and virtual folders, is there a way to back up all of those things so I don't lose them again?
[/quote]
geposted Fri 07 Dec 18 @ 7:32 pm
How do I get that?
Click into Settings, Options, then search for all settings, then scroll down to the Internet section, and set earlyAccessUpdates to Yes. As of about 30 minutes ago, V8.3.b4718 was released.
geposted Fri 07 Dec 18 @ 8:12 pm
