If you have a bad power bar and your audio system is plugged into it can it make your controller freeze up or cause any kind of audio drop outs ?
geposted Sat 08 Dec 18 @ 4:17 pm
yes and could cause worse .. i suggest you test on a good power bar and see if you have any issues
geposted Sat 08 Dec 18 @ 5:49 pm
