Topic: Knob/Slider on controller effect linking help?
Is it possible to have an effect turn on as you move the knob/slider strength and when you put the strength back to zero have the effect turn off?
geposted Sun 09 Dec 18 @ 5:27 am
Are you using a controller with Effects knobs ? If so, you can map that knob as ..
effect_slider X & param_smaller 2% ? effect_active off : effect_active on
where X is the Parameter number you wish to control (1 for 1st Parameter)
...or just
effect_slider 1 & param_smaller 5% ? effect_active off
if you only want to turn it off on zero but not automatically turn it on on other positions.
Thank you!!! You have just made my night :)
