Topic: Build 4720: missing video transitions
Please help, I noticed the video transitions folder is missing.
geposted Fri 14 Dec 18 @ 1:19 pm
May I know how to get back the transitions
geposted Thu 20 Dec 18 @ 9:59 am
What do you mean missing?
geposted Thu 20 Dec 18 @ 10:23 am
The video transtions folder.
geposted Thu 20 Dec 18 @ 10:27 am
Do you have this folder in your computer .. /Documents/VirtualDJ/Plugins/VideoTransitions (or /Documents/VirtualDJ/Plugins64/VideoTransitions for the 64-bit version) ?
Do you get the same list with both 32- and 64-bit versions of VirtualDJ ?
geposted Thu 20 Dec 18 @ 3:31 pm
Yes the folder is there but all transitions are missing
Do you get the same list with both 32- and 64-bit versions of VirtualDJ ?[/quote] both the same problem
geposted Mon 24 Dec 18 @ 5:26 pm
So there are no dll files within the folder? You can download transitions etc from within VDJ now - you know that, right?
geposted Mon 24 Dec 18 @ 5:31 pm
yes no dll files, i redownload a few but did not show in the transition column
My question is how can it goes missing mysteriuosly & even redownload it did not display?
geposted Tue 25 Dec 18 @ 3:39 pm
It looks like somehow you managed to select 'Boom' as the transition, which is why the drop-down opens in the wrong folder.
You can reset this by resetting the option called videoTransition
geposted Tue 25 Dec 18 @ 9:24 pm
The weird part is that even I reinstall VDJ, it still doesn't show the transitions.
geposted Wed 26 Dec 18 @ 8:22 am
You uninstalled including removing settings you mean?
geposted Wed 26 Dec 18 @ 8:38 am
I didn't remove the setting.
geposted Thu 27 Dec 18 @ 9:24 am
So it's not weird then that the settings didn't change
geposted Thu 27 Dec 18 @ 9:44 am
Was this ever resolved? I'm having the same issue. I was only "ignoring" transitions I didn't want. And now when I select to see the video transitions, I only see audio effects. AFU. I'm using the latest Rev of the software as of this date.
geposted Tue 04 Jun 19 @ 10:02 pm
NicotuxHome userMember since 2014
This one appears with too old skins created before "single source" & shaders exist. Transitions selection is not compatible anymore and skin must update
geposted Tue 04 Jun 19 @ 10:13 pm
I don't understand your reply. But I do thank you for offering to help. I'm running the latest version of VDJ and this is a VDJ 8 native skin.
geposted Wed 05 Jun 19 @ 12:29 am
jucenicPRO InfinityMember since 2012
Update VDJ to the last one VJ 8.3 b5002, I have that problem, I did the last update and everything back to normal
geposted Wed 05 Jun 19 @ 4:31 am
