Topic: Audio Dropout since Updating to Latest Version
Had been hesitant to update the software for a while, finally did it. At a gig tonight the sound dropped out. Controllers still worked but no audio would play. Had to shut down software, unplug and re-plug controller, then open VirtualDJ again for it to work. Happened on multiple controllers, using multiple USB cables. Is there a way to find out what version I was using prior to the update so I can reinstall (on a Mac) until the issue is resolved?
geposted Sat 15 Dec 18 @ 5:45 pm
Did the rhythmwave stop ? (Start to stutter)
This indicates the soundcard was lost...
Did you try to press ’apply’ in audio config ?
geposted Sat 15 Dec 18 @ 7:21 pm
