Topic: No Levels While Music Is Playing
I just updated VDJ and noticed I had no levels while the music was playing. I'm using DJ Dad Multi FX skin but i tried my other skins and it doesn't work there either. Is anyone else having this problem or did I turn something off?
geposted Mon 17 Dec 18 @ 4:49 pm
PhilWPRO InfinityMember since 2011
No issue here - have you checked your audio config? Rebooted your computer?
When you say “no levels” I am assuming no sound is being produced. Is the PFL working for headphones? Are you using a controller?
Edit: Mac or PC?
geposted Mon 17 Dec 18 @ 5:24 pm
Edit: Mac or PC?
PC (Laptop), no I mean on the skin beside the volume control level, the master volume level doesn't come up when music is playing. I have sound coming out my speakers/headphones, I noticed it after the recent update it was working fine before.
geposted Mon 17 Dec 18 @ 11:07 pm
The Master VU meters will not be available (or not showing any activity - depending on the skin), if your Audio Setup doesnt have "Master", e.g. your Audio setup is "External Mixer" with deck 1, deck 2, etc.
geposted Tue 18 Dec 18 @ 2:57 pm
I just reset to factory default and it came back, thanks for the help.
geposted Thu 20 Dec 18 @ 8:37 pm
