About VirtualDJ and DJing in general
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
Topic: songs loading on empty decks when i press play
my play button loads a song when i press play, is there a way to stop it from doing this?
geposted Mon 17 Dec 18 @ 11:12 pm
No, but may I ask why would you press PLAY on an empty deck ?
geposted Tue 18 Dec 18 @ 9:29 am
im trying to operate with djay pro at the same time
geposted Tue 18 Dec 18 @ 10:06 am
That's not a good way to go then.
You should NOT use the same controller on two different applications at the same time.
You CAN use 2 different controllers with 2 different applications at the same time (so that each application is controlled by one controller and provides feedback in one controller)
The problem is quite more complex than play button registering at two applications at the same time. All modern controllers receive feedback for their leds and other status from the connected application. If two different applications send different status messages back on a device, the device can develop unpredictable behavior for BOTH applications.
geposted Tue 18 Dec 18 @ 10:14 am
Not sure if he tries to run both apps at the same time, i could be wrong, but anyways, regarding his original question, yes, its possible, but requires custom actions.
For controller. you can map the PLAY button as .. loaded ? nothing : play_pause
Same goes for the skin, but you need to edit the XML and replace the button action (play_button) with .. loaded ? nothing : play_button
geposted Tue 18 Dec 18 @ 2:50 pm
