I hope someone can help me, by default Virtual DJ 8 can use mouse scroll wheel for adjust volume level but it change 3% by 3% for example: I have 100% and when I lower the volume with the scroll wheel the next percentage is 97% etc, I want it to change 1% by 1%. Thanks for the help
geposted Fri 21 Dec 18 @ 5:52 am
The only way to achieve this is to adjust your mouse scroll wheel sensitivity in Windows control panel. There should be an option that says "3 clicks at a time" for the scroll wheel. Change that to 1 click.
Other than that there's no other way...
geposted Fri 21 Dec 18 @ 7:42 am
