Is there any way to remove the Karaoke tab from the sideview?
geposted Sat 22 Dec 18 @ 3:57 pm
I have the same question. Adding any other options like AskTheDJ to sideview panel does make it gets pretty cluttered down there. would be great if I could remove things I'm not using. So, anyone?
geposted Wed 02 Jan 19 @ 10:51 pm
Probably only by editing the skin.
geposted Thu 03 Jan 19 @ 12:16 pm
I would love to see this ability too. I have never, and will likely not ever, do Karaoke, so I would much prefer to free up that slot in the Sideview for other things. I'm not terribly adept at skin editing, so it would be great to see this ability in a feature update!
geposted Mon 07 Jan 19 @ 5:54 am
Maybe it would be fine to allow to select sideviews individualy and choose their working mode (sidelist sampler automix karaoke folder...) instead
it is not a reason some don't need karaoke or automix or sampler to remove them, some may need more than one of them.
for now it is not possible by editing the skin as these sideviews are currently hardcoded
however addding a shortcut to "Ask the DJ" is easy as it is a virtual folder
geposted Mon 07 Jan 19 @ 11:42 am
