Alright. I've got an interesting one for you guys. I have a 2 deck controller. I use a 4 deck vdj skin because I will mix between decks 1 and 2 using the controller and 3 and 4 using the virtual crossfader. Every time I open VDJ I have to fix my settings to match this:
Is there a way to save this setting so decks 1 and 2 are not controlled by the virtual crossfader and decks 3 and 4 are? Is this a feature VDJ would consider working on in the future if it does not already exist?
geposted Fri 28 Dec 18 @ 1:39 am
oninit: deck 3 leftcross 'only' & deck 4 rightcross 'only'
geposted Fri 28 Dec 18 @ 5:19 am
Got it! Thank you!
geposted Sun 30 Dec 18 @ 6:12 pm
