I want to use the virtualdj 8 on my macbook pro 2017 but i cant! A message writes that i must open port8000. How can i do that?
Now I use it from my 'windows' laptop but i have a problem with the connection!!
Can you fix it?
Thank you very much and happy new year!! 2019!!
Can you fix it?
geposted Tue 01 Jan 19 @ 8:49 pm
Have you previously used cracked versions of the software?
geposted Tue 01 Jan 19 @ 9:41 pm
I am trying to change the skin in virtual dj 8
geposted Tue 01 Jan 19 @ 11:57 pm
geposted Tue 01 Jan 19 @ 11:58 pm
