Topic: Bug creating Playlists
Using b4720 there is a bug creating playlists.
Do the following:
1. If not existing create a virtual folder with some songs.
2. Rightclick on that virtual folder and "add to automix".
3. "save..." to a playlist.
4. The save dialog should display the virtual folders name. Do not change, just click "OK"
5. -> No playlist will be created.
However, if there isn't already a playlist named "default", a "default" playlist will be created with the next start of VDJ containing the songs you tried to save as playlist with the virtual folders name.
If you do the same with a second virtual folder the "default" playlist will be overwritten without notice.
geposted Wed 02 Jan 19 @ 10:51 am
If you do save and don't change the name, it will actually save the changes to the existing virtual folder.
geposted Wed 02 Jan 19 @ 11:13 am
That doesn't make sense to me. The dialog says "Enter name for playlist:"
And why does it create or save the automix list to the "default" playlist than?
geposted Wed 02 Jan 19 @ 12:12 pm
default is the one stored on exit so that the automix list is the same next time you open vdj
geposted Wed 02 Jan 19 @ 7:49 pm
