I have the new virtural dj its telling me theres an update. but when I say yes to in install notting happens but when I restart the software it appares again.
geposted Thu 03 Jan 19 @ 5:26 pm
On Windows are you an administrator and do you answer yes when Windows asks you if it’s okay to run the installer? If you’re on Mac sorry I can’t help.
geposted Thu 03 Jan 19 @ 9:53 pm
I am having the same problem with my laptop. I am running Windows 10 (as the admin). Nothing in my settings has changed since the last Virtual DJ update -- which did work. But now, I can see it downloading the update, then it asks if I want to install it, I say "YES", and it does nothing. I can tell because the version remains 8.3 b4592 -- rather than the latest 8.3 b4720 (which my desktop successfully updated).
geposted Sat 05 Jan 19 @ 7:14 pm
my asio wont appear when I load in pro
geposted Sun 06 Jan 19 @ 3:25 pm
Jarvis, you haven’t given us enough info to help. What controller and platform?
Also, you should start a new thread. Your post has nothing to do with VDJ updating automatically.
geposted Sun 06 Jan 19 @ 4:03 pm
I’m having the same issue on my Windows 10 PC. I also have a Windows 7 PC that I run as a backup. Today on the Win 7 machine the update yes/no came up, I clicked on “yes” to update, it did. On the Windows 10 PC when I click “yes”...nothing updates. I’ve rebooted, tried 4x, and nothing. No dialogue boxes come up asking for permission. The update just doesn’t happen.
geposted Fri 11 Jan 19 @ 4:38 am
I had exactly the same issue. I manually downloaded the newer version from the website and installed that way. Hopefully that will fix the issue, as I like the existing method.
geposted Sat 12 Jan 19 @ 8:29 am
If for some reason the automatic update fails, you can try to remove (if exists) the update.ready file you will find in /Documents/VirtualDJ/Cache folder and then restart VDJ.
If that fails again, then download and install the latest from http://www.virtualdj.com/download/index.html and let us know if you get the same issue on next available update
geposted Sat 12 Jan 19 @ 2:46 pm
DJDAD's suggestion solved the issue...we're good to go! Thanks for your support and advice!
geposted Fri 10 May 19 @ 1:03 am
Something changed imho with the last 2 updates that is causing issues with some users. I took that last update and had to wipe out vdj and do a reinstall, and rescan on my database.
geposted Fri 10 May 19 @ 4:14 pm
I’m having issues with windows constantly forcing updates , Now I have two laptops that won’t work with my mixer or controller . The vertical Dj software won’t recognize my mixer or controller Because of Windows update . I’ve tried uninstalling history updates wouldn’t work
geposted Wed 12 May 21 @ 7:24 am
Hello
In my opinion I would have rather done a restore of the windows system, to the date when everything worked well.
geposted Wed 12 May 21 @ 8:34 am
Which mixer/controller is not detected ? Perhaps try to re-install their drivers (if they have such)
geposted Wed 12 May 21 @ 9:23 am
