Hi, everyone. I can successfully drag and drop files from Windows Explorer onto a VDJ deck, but not from MediaMonkey. I'm pretty sure iTunes works too although cannot test as I no longer use it.
MediaMonkey drag and drops to VLC media player just fine, but not to Virtual DJ. No error is reported, just the drag and drop mouse cursor reverts to the normal cursor when I release the left button.
I noticed this quite some time ago, just hadn't got 'round to asking about it.
geposted Mon 07 Jan 19 @ 6:52 pm
Virtual DJ has its own browser and database - you don't (shouldn't) need to drag and drop tracks from anywhere.
geposted Mon 07 Jan 19 @ 8:05 pm
I'll admit it's not something I do frequently but sometimes it is useful to be able to do it.
geposted Mon 07 Jan 19 @ 10:55 pm
I do everything in VDJ but tried MM and it works for me. Drag/Drop it in a Deck or Sidelist or Automix section, all works.
geposted Tue 08 Jan 19 @ 4:08 pm
Thanks, Magic DJ. After reading your response, I decided to try the 32-bit version of VDJ and it worked. 64-bit did not. I believe MM is a 32-bit app, so maybe that has something to do with it.
geposted Tue 08 Jan 19 @ 4:33 pm
Will be fixed for 64-bit version in a future update.
geposted Fri 11 Jan 19 @ 7:55 am
Great, thank you
geposted Fri 11 Jan 19 @ 3:03 pm
