Topic: Lock Folders
swattyPRO InfinityMember since 2012
I believe a new feature has been added to allow the locking of folders in the browser config settings. I suspect there is a bug in this function because when selected as "lock folders" set to on, it is still possible (I did it accidently) to move folders down the list or un-nest them. I did not realise I had this function set to on so could not work out why I could only move folders down the list and not freely re-arrange them.
I can't find this function mentioned in the on-line manual so did not know it existed. Is there a list available of the latest features added/altered each time the software is updated?
geposted Thu 10 Jan 19 @ 11:36 am
I can confirm the bug. But a fix is on its way :)
geposted Thu 10 Jan 19 @ 11:59 am
When did the "lockFolderOrder" setting appear as I don't recall seeing it in any of the changelogs?
No point implementing new things like this if nobody knows about it.
geposted Thu 10 Jan 19 @ 2:49 pm
BUILD 4717 (2018-12-06)
-Fix video sample recording issues
-Fix shader position when transparency is used
-miditovst_active action added to toggle midi to vst on/off
-After recording a mix, add cue points for each track played
-Loop Roll compatible with colorfx
-New tab style for bottom sideview toolbar
-lockFolderOrder option added
geposted Thu 10 Jan 19 @ 3:22 pm
Ah, only shows on the EA log then. When it was rolled up to 4720 there was no mention of it.
geposted Thu 10 Jan 19 @ 3:46 pm
