I've asked more than once why I can't change folder icons in vdj on Mac but it works fine on windows....To this date no answer. The settings I clicked yes but the folders still remain default... Other issue I have is on windows, Vdj 7 and earlier versions of vdj 8 windows settings for the snap cursor (mouse pointer) to default box works inside vdj but not anymore... Anyone care to explain what I need to do or is it a glitch.. Thank you.
geposted Fri 11 Jan 19 @ 6:06 pm
Have you raised a support ticket?
geposted Fri 11 Jan 19 @ 6:15 pm
It is indeed not possible to use OS folder icons on mac.
Due to VirtualDJ using customized dialogs, it may indeed also not work correctly with windows snap settings.
geposted Fri 11 Jan 19 @ 7:43 pm
