Hi all
I know the S4 mk1 isn't natively supported but I know there are a lot of folks who use it with VDJ8.
I need serious help. Every now and then VDJ 8 will glitch while I'm playing. If I had to guess, I'd say it's when the software is under load, like pitch bending while having an effect going, but not always.
I have a feeling it could be a latency issue, but I can't seem to get it sorted. It's definitely not the controller (as it works perfectly in Traktor) and it's not the software (as it works perfectly with my MC6000).
Here's the info
PC specs: Windows 10 Pro 64 bit, core i7 2.4ghz, 8gig ram, Nvidia 840m.
Software: VDJ 8 build 4720.1471 Latency set to Auto (512) and ultraLatency is on.
Asio settings are: 44100 hz sample rate, 512 samples process buffer and 2ms USB Buffer.
Please help
Here's the info
Please help
geposted Sat 12 Jan 19 @ 9:41 pm
Ditch the asio driver try wasapi instead, turn ultra latency off (s4 user)
geposted Sun 13 Jan 19 @ 6:19 am
Thanx man. I'll give it a spin. Should I use master and monitor (for headphones) or just master?
geposted Sun 13 Jan 19 @ 12:07 pm
Master, monitor.
geposted Sun 13 Jan 19 @ 12:27 pm
