this build doesn't start quantized from cue 2
have smart cue on
went back to 4720 and problem went away
have smart cue on
geposted Fri 18 Jan 19 @ 10:39 pm
With FRUiT skin the Filter does not expand to the color effects.
geposted Sat 19 Jan 19 @ 12:52 am
Can anyone else confirm or is it just me.
BTW that is skin related and nothing to do with my issue.
geposted Wed 23 Jan 19 @ 3:41 pm
You mean only the second cue point?
geposted Wed 23 Jan 19 @ 5:12 pm
That was the one giving me the issue. I didn't notice it with the others but I also didn't test it specifically. I downgraded and it was back to normal.
geposted Wed 23 Jan 19 @ 5:36 pm
I tested it just right now on 4742 and I can't find any problems.
geposted Thu 24 Jan 19 @ 4:54 am
Thanks
geposted Thu 24 Jan 19 @ 10:18 am
wickedmix wrote :
Thanks
Thanks
No problem!
(Maybe you had a deck set as master accidentally or something... This happens to me sometimes.)
geposted Sat 26 Jan 19 @ 4:23 am
not sure i will have to test again when i have time.
staying with the public build for now.
geposted Sat 26 Jan 19 @ 3:14 pm
