Topic: Songs From Automix Go To Sidelist After They're Played
Recently, whenever I play a song from an automix list, when the song finishes, the played song moves to the sidelist. The "save unplayed to sidelist' is set to yes. When it's set to no, the played songs don't go to sidelist, but then unplayed songs loaded on decks that are removed or replaced don't go to the sidelist.
It's never done this before. Just started with the last build. Anyone have any insight?
Using latest build. 4742.1478. Default skin. Win 10 latest updates.
geposted Sat 19 Jan 19 @ 4:08 pm
Do you have the deck faders up? If not it won't detect as played.
And that's the answer. I have a list playing as bumper music for karaoke. Fader down when singer is singing. When the singer is done, I'll fade up and whatever is playing in the list plays and gets marked as played. Thank you.
