Hi I'm thinking on getting a Midi Fighter Pro BeatMasher, there is one selling cheap nearby.
Will I be able to map it to Virtual Dj8?? buttons,faders,knob & LEDs ??
Its not included in the Hardware compatible list
https://www.virtualdj.com/products/hardware.html
geposted Thu 24 Jan 19 @ 10:16 pm
Hello I got myself the MidiFighter Pro its great! the arcade buttons are perfect! IMO they feel better than AKAI pads.
need some help please, can I reverse/ invert a fader ? what the script to use?
I wanted the map a (HW)fader to sampler volume but it is working "upside down" : fader up=zero volume, fader down=ful voume , help!
thank you
thank you
geposted Sun 27 Jan 19 @ 8:21 pm
Try adding
param_invert &
before your script
param_invert &
before your script
geposted Sun 27 Jan 19 @ 9:11 pm
thats it, thank you
geposted Sun 27 Jan 19 @ 9:46 pm
