i have 2 controllers from pioneer ddjsx2 and ddjsz2 and went you plug the controllers works good until you use the pitch slider and the pitch reset the controllers flashes and cut the audio and the leds on pads turned off by self and stop working until you restart virtual dj again, works good whit out problems until the update b4675
geposted Mon 28 Jan 19 @ 4:07 am
