Hi there,
Despite several attempts at using ESI Maya 44 USB+, I just can't get rid of the tinny or distorted sound when using timecode. So I'm considering purchasing the Pioneer DJM-450, but was wondering whether I can use this with the VDJ timecode vinyls, or is it just limited to Rekordbox DVS?
Thanks in advance VDJ Community !
geposted Mon 28 Jan 19 @ 6:22 am
if you're feeding the turntable directly into the MAYA then of course you'll get tinny sound - turntables need RIAA preamps. The inputs of the MAYA are just standard line level, not for turntables. https://en.wikipedia.org/wiki/RIAA_equalization
VDJ can recognise all the popular timecodes, so it doesn't matter which vinyl you use.
The mixer itself couldn't care less about which timecode is going through it - it merely passes the signal to the software.
geposted Mon 28 Jan 19 @ 6:24 pm
the old maya 44 had riaa preamp...are you sure the new 44+ doesn't have? i used to work dvs with it flawless
geposted Sat 02 Feb 19 @ 12:29 am
Are you sure? It's not mentioned on the product page and there are no Google results saying it has RIAA preamps. Also I've got one of these myself, and AFAIK there's no RIAA preamp.
geposted Sat 02 Feb 19 @ 8:01 am
yeap I do remember clearly that i used to use it with vdj and timecode and it worked flawless (in ver. 7)
geposted Sun 03 Feb 19 @ 10:05 pm
I think it was the software that had a preamp, not the interface.
geposted Mon 04 Feb 19 @ 5:20 pm
I don't think the maya 44 had pre-amps either, and the inputs were not very sensitive.
It can work for dvs-purposes though, as long as the signal is clean enough, and the needle/cartridge used has a high enough output.
(For optimal results, adding a pre-amp, or using turntables with line output would still be recommended to get a decent signal-to-noise ratio, but for dvs it does not have to be a riaa pre-amp, as the equalizer curve is not very important for reading the digital signal)
geposted Mon 04 Feb 19 @ 5:27 pm
This makes me wonder what the sweet spot in the RIAA curve is (freq than neither needs a cut nor boost)
With the info above leads me to guess its somewhere between 1 & 3 KHz
2019 and we're still talking about RIAA, turntable makers need to get their act together.
geposted Mon 04 Feb 19 @ 5:46 pm
It's just dawned on me I've got my wires twisted here. He's using timecode, so the audio playing back from VDJ should be clean, not tinny. The timecode's just the control signal. Maybe he's hearing the TCV on top of the normal audio, and that's what he means by tinny?
geposted Mon 04 Feb 19 @ 5:53 pm
