Is there a way to give every single pad an own menu?
For example to quickly colorize or rename cues by rightclicking on the dedicated pad.
Or other functions that relate to single pads.
This function could be placed perfectly in the "Pad Editor"-Window next to: Push-Action / Pressure-Action / Color / Menu
- If no pad has a own menu the pad_menu could appear on every pad.
- If a pad has an own menu then the menu for this pad could pop up by rightclicking on it, and the rest of the pads use the normale pad_menu.
- Also there could be "pad_menu" to open the main pad_menu and "pad_menu 1, 2 ,3, etc." to open the menu of pad 1, 2, 3, etc.
geposted Mon 28 Jan 19 @ 7:21 am
No, mostly because pads and pad editor is meant to be used in conjunction with a controller.
That's why pad editor says SHIFT + PAD and not "right click" action.
Also for most cases using the parameters buttons to navigate through sub pages of the same pad page is more than enough.
I can see your point regarding hotcues, but I don't think it can be done with the current tools.
Maybe in a future version the hotcues themselves can provide a right click option...
geposted Mon 28 Jan 19 @ 5:24 pm
