Hi, all new to this forum.
Im looking a buying a used denon dj mc4000 for a very good price, but it has a fault on the master volume which makes a crackling noise when turned , is there an easy fix for this?
Is it possible to re assign the master volume using mapping to another knob like booth volume ??
geposted Mon 28 Jan 19 @ 1:04 pm
Contact spray, failing that you're replacing the potometer.
I believe the dial is hardware based so you can't map it, you could just use booth as your output
geposted Mon 28 Jan 19 @ 1:15 pm
Hi , can you recommend a contact spray ?
geposted Mon 28 Jan 19 @ 1:43 pm
http://lmgtfy.com/?q=electrical+contact+spray
make sure its for electrics and not I repeat not WD40
geposted Mon 28 Jan 19 @ 2:04 pm
