Hi,
I have noticed the following:
for chart Top 40 music, I have songs in folders, 2015, 2016, 2017, 2018 2019.
I tag the music really well.
However, in the 2019 folder, the YEAR tag does not show up. It is blank.
I have checked in my Tag Editor (Mp3Tag) and the YEAR field is definitel filled in with 2019
This happens on my desktop PC (Windows 10 64 bit, Intel Core2Duo Processor) and my work Laptop (Windows 7 64bit, Intel i7 processor).
EDIT: the full path is D:\Users\Lee\Music\2010's\2019\
Thanks
Lee.
Thanks
Lee.
geposted Fri 01 Feb 19 @ 10:53 am
Have you tried to reload the tags?
geposted Fri 01 Feb 19 @ 7:42 pm
No.
Let me try.....
Worked!
Thanks Phantom.
That's another setting I have discovered.
9999 more to learn
Let me try.....
Worked!
Thanks Phantom.
9999 more to learn
geposted Sat 02 Feb 19 @ 1:40 am
I appreciate getting my tags reloaded, however I have added more tracks to the folder and I have to "reload tags" again to get the year to show up just as before.
It only happens in the 2019 folder.
This must be a bug??
Lee.
Lee.
geposted Mon 04 Feb 19 @ 1:20 pm
Check your settings. getTagsAuto and setTagsAuto should both be yes.
All files I import to VDJ have the correct year in the browser.
geposted Mon 04 Feb 19 @ 1:40 pm
Thanks for the quick reply mr Radcliffe!
Yep, you were correct. Those settings were set to NO.
So many settings!!!!
Well, if I ask a question about every setting, then eventually I will get things set up perfectly.....
Thanks again :-)
Lee.
Thanks again :-)
Lee.
geposted Mon 04 Feb 19 @ 1:52 pm
