Sound occasionally cuts off i already tried the drivers on the laptop and controller its all optimize aswell as the latency. I took a video of the problem. I tried to contact support but all i get everytime is automatic no reply emails. Im really frustrated if i dont get a fix im canceling my subscription and move to other sofware
geposted Fri 01 Feb 19 @ 4:41 pm
Ok more info
laptop specs
controller model
latency settings
wasapi or asio
laptop specs
controller model
latency settings
wasapi or asio
geposted Fri 01 Feb 19 @ 4:55 pm
Laptop alienware 16gb ram 1tb ssd
Ddj ergo / ddjrz
Asio settings standard or even tried to raise it and still does it
Ddj ergo / ddjrz
geposted Fri 01 Feb 19 @ 5:31 pm
Im not sure if i can post link but here is the video showing the problems
https://drive.google.com/file/d/1kGFppjXO-p1bugk3RUqSxtxAQuAKqcQm/view?usp=drivesdk
geposted Fri 01 Feb 19 @ 5:33 pm
Will probably be a bad Dell driver causing latency spikes. Comes up here regularly.
geposted Fri 01 Feb 19 @ 6:10 pm
Have you actually used latencymon to check your system?
Also try wasapi
Also try wasapi
geposted Fri 01 Feb 19 @ 6:13 pm
