Hey guys, I have a small issue with my cue pad colours. Im using a launch pad to set and playback cues and have the shift button to delete them. When you press the shift button the pads are meant to go white indicating they are ready to delete however only the red (Deck 1) pads go white?? The deletion still works as normal but the pads not changing colours is annoying! I don't believe its the launchpad as even with the default mapping which i remember working before it still does not work and i have tried it on two separate cpus, my old laptop and my new Macbook Pro. I have read thru settings to no avail!! Any help would be greatly appreciated, Thanks guys :)
geposted Sun 03 Feb 19 @ 5:18 am
*UPDATE* When running the launchpad alone the colours work perfectly! When i have my 4 Denon DN-S3700s plugged in and connected the problems start!
geposted Sun 03 Feb 19 @ 5:42 am
