Hi!
I went into the POI Editor and programed hot_cue 9 to be a hot_cue and also a saved_loop.
Just like this:
![](/img/285705/35298/cue_select.png)
After that I wanted to select hot_cue 9 via cue_select (with +1 or -1), but VDJ skips this hot_cue.
I tried every other available POI-type (action-point, remix-point, beatgrid anchor, etc.),
but it only selects this specific cue if it is set as Hot Cue.
It does not select the cue if it is set as an other type.
I also tried it with cue_select 9.
In this way the cue gets selected, but if I trigger it with the keycue pad_page for example, it DOES play the hot_cue but it DOES NOT set the loop like it should by pressing the normal hot_cue 9 button.
Just like this:
geposted Mon 04 Feb 19 @ 7:06 am
