Topic: Backup Database Option
Hi,
Backup Database Option...
That is an excelent Idea, but, How does it work? I don't se any options on the Settings Window. Or it just runs automatic every certain amount of days?
Thank you in advance.
DjChachi
geposted Sat 09 Feb 19 @ 12:34 pm
Check the same spot that'd you'd clean missing files from database.
geposted Sat 09 Feb 19 @ 1:31 pm
@ locodog
Big Thanks
DjChachi
geposted Sat 09 Feb 19 @ 3:19 pm
freppaPRO InfinityMember since 2002
I cant see this working on external drives ?
geposted Sun 10 Feb 19 @ 2:48 pm
The database.xml in the zip contains the information from all connected drives.
geposted Sun 10 Feb 19 @ 2:52 pm
ahh, thanks.
I thought it was stored on the external as backup.
geposted Sun 10 Feb 19 @ 7:59 pm
Just checked and my external hd database.xml is 46.8mb
The backup database option, after been unzipped, is showing the database.xml as 44mb
geposted Sun 10 Feb 19 @ 8:04 pm
If your database file has been around for a while it might contain some empty space between the entries where deleted files used to be, so that probably explains the size difference
geposted Mon 11 Feb 19 @ 2:30 am
Hello, in my last gig , the last Saturday my external drive database were broken and recovered after asking me and I hit yes. But now all cues are missed in all songs in the drive and I can't find where the backup database xml is stored. I searched the external drive there is only the broken database files, and since I am using a pc I tried to search the virtualdj folder in my documents but I found nothing, can you please help with this issue? Thank you:)
geposted Mon 22 Apr 19 @ 8:46 pm
If you ever did a database backup, it should be stored in a "\Documents\VirtualDJ\backup\" folder, and be named something like "2019-04-23 12-02 Database Backup.zip"
geposted Tue 23 Apr 19 @ 10:03 am
I don't have any folder called backup in this directory :(
geposted Tue 23 Apr 19 @ 11:46 am
geposted Tue 23 Apr 19 @ 11:52 am
Then are you sure you ever did a backup?
Like this:
geposted Tue 23 Apr 19 @ 11:58 am
ahaa, so there no way to recover my old database xml file before the Saturday gig :(, but I have the broken one, can I do something to repair it ?
geposted Tue 23 Apr 19 @ 12:31 pm
Like this:
I did it now, but will it be automatic ? or every time I have to do it manualy ?
geposted Tue 23 Apr 19 @ 12:39 pm
