Dear all,
Some of the cutomizations I have set in VDJ are not loading anymore (Custom button, column in the playlist, audio profile). I thought VDJ went back to default settings, but actually some other settings have (cue points, folder organization, plug-ins are still here as well as downloaded FX...). Has this happened to anyone? how can I load the latest version of my settings?
thanks a lot
thanks a lot
geposted Wed 13 Feb 19 @ 1:39 pm
Ho Yes!! Unfortunately !!
Custom buttons (as well as browser columns, windows positions, variables ...) are stored in setting, so far you loose them in many situations
1) VDJ Crash before you exit
2) VDJ Hangs
3) The previous both but for the computer
4) Settings.xml file corrupt,
5) Update with some incompatible setting file
... and many more other reasons
For the 4 first a bacup of settings.xml is enough
Badly, everything have to be redone in the other cases
Or DANGEROUS way : Save your needed tags from settings.xml and overwrite those of the new one
i.e. Everything between: <customButtons> and </customButtons>
2) VDJ Hangs
geposted Wed 13 Feb 19 @ 6:41 pm
thanks a lot Nicotux,
so there's no way I can recover these settings?
thanks
Olivier
thanks
Olivier
geposted Thu 14 Feb 19 @ 1:44 am
unless you have an undelete tool and some chance...or somone else in the forum have a solution, i'm affraid no :(
geposted Thu 14 Feb 19 @ 2:06 am
