I have a question I want to use Sound FX on my mix but need help. When I use an FX like loop roll it works great and I like it, I just would like my music to play where the loop is being used and not keep playing, because I noticed the song seems to skip ahead when I stop the loop I am at the end of the song. I just want to use loop roll and not have my song skip to the end, or continue playing but remember where I started the loop and continue from where I started the loop.
I am trying to use Loop Roll which I downloaded from the download section.
Any way to not make the song skip forward while using loop roll?.
geposted Wed 20 Feb 19 @ 1:33 am
Open the fx gui (+ under the fx select dropdown) Check what buttons you have selected (slip, stop)
geposted Wed 20 Feb 19 @ 1:44 am
Thanks for the help. I am using loop roll and when I open the settings there is not an option like the one in the picture. I still need some help, does anyone think there is a setting to stop the song from skipping forward, maybe in the options where all the controller and sound settings are at?.
geposted Wed 20 Feb 19 @ 4:09 am
Sorry I misread and pictured loop out, not loop roll
The whole point of loop roll, is that it rolls (slips).
Why not just use the loop feature? (not the fx)
geposted Wed 20 Feb 19 @ 4:23 am
