Topic: BPM has gone from my library
Hello I have start the program and all analyzes for BPM er be delete! You know how i can fixe all BPM with doing again? This problem I has have before. Thank you for help
geposted Thu 21 Feb 19 @ 9:46 am
It usually happens if either:
1. you loose your database.xml file (where it's all stored)
2. you don't have the rights on the operating system to update the database.xml file
3. you move you files around on disk, so that the path no longer match, and VDJ sees them as new files
Could any of those 3 be the reason in your case?
geposted Thu 21 Feb 19 @ 10:30 am
Only once I've had it (2-3 years ago) when vdj didn't find the database.xml
I closed vdj and reopened and everything was as it should be.
geposted Thu 21 Feb 19 @ 6:29 pm
