Topic: Load srt subtitles to movie in Virtual DJ
Hello there!
I haven't found any answer anywhere so: is this possible to load srt subtitles with timing to movie played in VDJ?
I thought of directvobsub plugin but can't figure out how to load the plugin.
Thank you for your help in advance.
geposted Thu 21 Feb 19 @ 11:12 pm
Movie? you know this is djing right?i think you need something else to play your movies If your playing it at a event i hope you got licensing for it..
geposted Sat 16 Mar 19 @ 11:13 pm
freppaPRO InfinityMember since 2002
This can be done with Videoeditor if you are a licenced user or you can make your own on the web.
Open the videoeditor with audiofile and try to search for text.
If you dont find the text in videoeditor try to use http://lrcgenerator.com/
geposted Sun 17 Mar 19 @ 8:26 am
