I just got my new Numark Dashboard, and it works great with my DDJ-SX2 and VDJ. But, is there a way to change (zoom out) the waveform in the middle-screen?
Now it´s about 5 beats wide. Is there a way to make it like 10beats wide?
Also, is there a way to make the waveform in left and right skreen a little bigger?
Regards
Regards
geposted Tue 26 Feb 19 @ 9:14 pm
https://www.virtualdj.com/manuals/hardware/numark/dashboard/settings.html
Parameter 2 adjusts waves zoom
You cant change anything in the screens layout
geposted Tue 26 Feb 19 @ 11:53 pm
Thanks
I´ll try that. :-)
I´ll try that. :-)
geposted Wed 27 Feb 19 @ 6:56 am
have this device too.
My question is ,
If I set the zero DB to -9 then the waveform on the displays is much too thin.
You can then hardly see the beats spikes properly.
Can I somehow set this in the mapping, that the waves do not respond to the volume, and then become narrower?
My question is ,
geposted Wed 27 Feb 19 @ 2:11 pm
