Topic: Need help in setting up Virtual DJ 8 for Denon MC2000
budhiyoHome userMember since 2016
Hi all,
I would like to know how to set up the Virtual DJ 8 and Denon MC2000 properly. I made sure that the Default Soundcard is my Laptop Soundcard, NOT the Controller's. I also used the Denon ASIO driver ver. 1.0.0 since I couldn't get a hold of the new driver. So far, I was only able to get sound from the controller by plugging in my headphones to it and by choosing the "Denon MC2000" option with the sound coming from Channel 3 and 4 for some odd reason, =using the Denon ASIO driver ver. 1.0.0. I would like to know how to configure the settings to be able to play through my laptop's speakers and both of the speakers and the headphones as well. Any help is appreciated and the pictures showing the settings of my ASIO driver and Virtual DJ audio settings, thanks!
geposted Thu 28 Feb 19 @ 12:59 pm
geposted Thu 28 Feb 19 @ 1:09 pm
Set Output 1&2/ master to your internal soundcard if you want to play the master through the laptop speakers.
Headphones will still go through the Denon.
geposted Fri 01 Mar 19 @ 8:44 am
