Topic: Remove VDJ Logo
hejzanPRO InfinityMember since 2009
I´m a PRO member and cant find where I can remove VDJ logo,
How do I do that?
geposted Fri 01 Mar 19 @ 12:06 pm
In options set videoLogo = No
geposted Fri 01 Mar 19 @ 12:49 pm
Cant Find it.
Haved looked over and over again
geposted Fri 01 Mar 19 @ 2:55 pm
geposted Fri 01 Mar 19 @ 3:08 pm
djdad wrote :
Big THANX you saved my day :)
geposted Fri 01 Mar 19 @ 3:19 pm
Thank you for that, very useful.
While we're at that place in Options, I can see an option for videoLogoImage
What filetype and size are necessary for that, or can Plain Text be used ??>
geposted Fri 01 Mar 19 @ 9:53 pm
Pro license required to use own logo image
geposted Sat 02 Mar 19 @ 3:21 am
freppaPRO InfinityMember since 2002
geposted Sat 02 Mar 19 @ 5:21 am
I pay the $19 a month and it says Pro License.
Why when i turn off the annoying Virtual DJ Logo does it say only pro users can turn this off?
geposted Wed 27 Mar 19 @ 2:51 am
PhilWPRO InfinityMember since 2011
You need to log in within Virtual DJ with the same credentials as this forum.
geposted Wed 27 Mar 19 @ 3:20 pm
I am a pro owner, I have said "no" under logo and I am logged in with same user to software it still does not remove logo. what is the problem. on a brand new MacBook Pro i9 all newest os and update virtual dj8
geposted Thu 04 Jul 19 @ 4:57 am
...on a plain video output, or using a VideoSkin?
geposted Thu 04 Jul 19 @ 4:21 pm
I see I think that was my problem! I had a skin on! I just bought a new I9 MacBook Pro and have switched to the 8 version over 7. so a new element to me! thanks brother have a gig tomorrow and that helped!
geposted Thu 04 Jul 19 @ 4:50 pm
