Topic: Edit Field1 (User 1) using script
BLG_VDJControlleristMember since 2018
Is there a script to edit Field1 in Tag Editor? I have tried various permutations using the browsed_file script with no luck. I have also tried using User 1, which is the Filter Folder name for the same field.
TIA.
geposted Sat 02 Mar 19 @ 11:45 pm
NicotuxHome userMember since 2014
browsed_song 'field1' edited
will write "edited" in field1 of selected track
geposted Sun 03 Mar 19 @ 1:12 am
Will give it a shot. Thank you.
geposted Sat 09 Mar 19 @ 4:26 am
Got it to work, so thanks for that.
Ideally trying to accomplish two tag edits at once. The first part of this scripts work, but the Field1 portion does not.
doubleclick ? browsed_file_color "#FFFF6FCF" and browsed_song 'field1' "edited"
Any advice? TIA.
geposted Sat 09 Mar 19 @ 4:33 am
doubleclick ? browsed_file_color "#FFFF6FCF" & browsed_song 'field1' "edited" : singleClick
geposted Sat 09 Mar 19 @ 4:43 am
Excellent. Can you direct me to a post on Script School that explains the need for the single click action?
geposted Sat 09 Mar 19 @ 7:25 am
Not really,... your script starts with the query
doubleclick ?
therefore this could be false and would need a reply for a single click.
geposted Sat 09 Mar 19 @ 7:43 am
OK. Got it. Just wondering what the rule was for that.
It worked as a single command without, so was curious if there was some hard logic behind it.
geposted Sat 09 Mar 19 @ 8:15 am
Indeed no need for the singleClick part if you don't want anything to happen when only single-clicking.
geposted Sat 09 Mar 19 @ 8:18 am
I see the difference between AND and &. Forgot about that.
Now can you use a script to change file type from video to karaoke??? I haven't tried any scripts for it yet, as I am unsure that type is a variable that can be changed since it is not a tag per se.
geposted Sat 09 Mar 19 @ 8:27 am
