Hi Guys, Is there a way to just use the keyboard to load a song onto the deck? And if so how.....
Cheers guys in advance!
Marmalizer.
Marmalizer.
geposted Sat 09 Mar 19 @ 4:19 pm
the script is
load
or
deck X load
x being a deck number, or left or right
load
or
deck X load
geposted Sat 09 Mar 19 @ 4:26 pm
Hi locodog and thanks for the reply.
I'm a complete amateur with Virtual DJ... Can you explain that process in more detail? Apologies for being a complete biff with it. :)
Marmalizer.
Marmalizer.
geposted Sun 10 Mar 19 @ 8:12 am
It's real easy
settings>controllers pick the keyboard mapping, click inside the key textbox, press the keyboard key you want to use, put the script in the action textbox, save and test.
geposted Sun 10 Mar 19 @ 12:48 pm
You can also use the command "browser_enter".
This will load the selected song to the next free deck.
geposted Mon 11 Mar 19 @ 9:02 am
As per PachN I also use the browser_enter command instead
geposted Mon 11 Mar 19 @ 6:43 pm
