Hi guy,
I need your help!
I just updated my Recordbox software, however, it changed my settings on virtual Dj because that's what I use. so when I select Pioneer XDJ-RX2 one the audio setting--master and headphone, it can automatic as Pioneer DJ XDJ-RX2 (chan 1&2 Master and chan 3&4 headphones)
In this case, there is no sound on my headphone . I can't heat any sound on the cue .
It was fine before but after the update it stops working.
Please what should I do?
Thank You.
DJ Desanto
I need your help!
Thank You.
DJ Desanto
geposted Mon 11 Mar 19 @ 2:54 pm
Have you installed the Drivers ? If not, do that from https://www.pioneerdj.com/en/support/software/xdj-rx2/#drivers
The default Audio setup is indeed Master & Headphones to Chans 1,2 & 3,4 as per the manual...
http://www.virtualdj.com/manuals/hardware/pioneer/xdjrx2/setup.html
.. but could be used in the other mode (Hardware) as well, as mentioned in the manual.. http://www.virtualdj.com/manuals/hardware/pioneer/xdjrx2/mode.html with Deck 1, Deck 2 (Ext mixer setup).
geposted Mon 11 Mar 19 @ 3:14 pm
I use my XDJ-RX in RX mode (external) always. Don’t think I’ve ever used it in internal mode since I bought it.
Just seems a shame to waste the great on board effects in built on tbe RX units.
Give it a go you may prefer it
geposted Mon 11 Mar 19 @ 6:41 pm
