When I use a controller pads to start / stop any kind of effect, then it's strength is always reset. Even if I pre-define it, it simply reset. When I use the skin and push the "pads buttons", then it reset the STR as well. However (and here comes the funny part), when I simply push the button where I can select / choose effects, it will not reset the strength. I can imagine two scenarios:
1.- Develop a possibility to pre-define the strength
2.- PADs buttons should not reset strength or at least there should be an option to choose the behaviour
However, both would be great. What do you think?
geposted Wed 13 Mar 19 @ 4:58 pm
How is the pad mapped ?
geposted Wed 13 Mar 19 @ 8:07 pm
Thanks for asking. The mapping is the default. Wheter I use my controller or not, I can re-generate the same symtom.
I could create a short video to demonstrate the situation if it would help to better understand my problem.
geposted Thu 14 Mar 19 @ 7:05 am
By effects, perhaps you mean samples and the default Sampler pads psge ?
geposted Thu 14 Mar 19 @ 7:12 am
I'm talking about effects. I was able fix the sampler pads with made custom configuration buttons...
I've tried to make a short presentation video about the issue. If you need, I could demonstrate it more.
https://www.youtube.com/watch?v=eDrS4m3XD_U
geposted Fri 15 Mar 19 @ 9:49 am
Ah i see now, you were referring to the PartyMix PM FX Pads page.
Yes, those Pads have pre-defined parameter values, so they dont just trigger Effects. Reason made that way is because the PartyMix doesnt have Effect Parameter knobs and we wanted to ensure that they will sound decent regardless the previous parameter settings.
If you want the Pads to just trigger the Effect, you will need to edit the actions of the PM FX Pads with the Editor and get rid of the effect_slider actions
geposted Fri 15 Mar 19 @ 10:33 am
The problem is still the same when I unplug the controller and trying the same. It will reset. How could I reconfigure this?
geposted Sat 16 Mar 19 @ 7:15 am
And is there any documentation available how could I reconfigure the PADS? Because it seems these parameters are hard-coded and I can see only PAD1 ... PAD4, but can not find how could I reconfigure it for Effects.
geposted Fri 22 Mar 19 @ 7:34 am
With the PartyMix plugged, open VirtualDJ. Use the default skin, and from the Pads Page selection drop, select "edit" to open the Pads Editor.
Below is the Pads Editor showing the PM FX Pads page selected and the assigned action for Pad 2.
If you dont want the Pad to set the effect's Parameters, instead of having
, edit the action to just
effect_active 'Flanger' & effect_slider 'Flanger' 1 90% & effect_slider 'Flanger' 2 75%
geposted Fri 22 Mar 19 @ 8:12 am
Thank you very much! Amazing! I have never found this possibility before. Wow! Works great now, thank you!
geposted Mon 25 Mar 19 @ 7:49 am
