Hi all,wanted to find out if vdj already has this feature cuz i cant seem to find it anywhere in the software. If there is a possibility,what scripts do i have to write to get vdj to record my sequences etc etc. thanx
geposted Fri 15 Mar 19 @ 10:24 am
They do have a built in sequencer in the sampler section. Just make sure your samples are set as a loop. Once you trigger {depending on trigger mode *play,hold,etc.*} the sample button, let it play. Go to a different sampler tab and trigger a sample and keep repeating and boom Remix Time!!!!!
geposted Tue 19 Mar 19 @ 2:03 pm
P.S. If you want to record what you're doing, just hit the record button. VDJ 2018 has an option when you record, it starts recording once it hears a sound!
geposted Tue 19 Mar 19 @ 2:05 pm
No - what you describe is not a sequencer. That's just you manually playing loops.
It's been asked for already. Whether they'll ever do it is another question.
geposted Tue 19 Mar 19 @ 5:20 pm
Not sure if the Ziglar is talking about a serato flip style feature possibly?
geposted Wed 20 Mar 19 @ 12:07 pm
VDj already has some Serato Flip Features but they have to be activated using scripts.(Example: To Skip certain Sections of a song) .But we dont have all the full features of flip(e.g . live beat/remix recording). Our Sampler also has a few limitations which i hope will be improved on with time. ( Example : The ability to set cue points in a sample and start a sample playing from a specific cue point ). Hopefully, these features will be implemented..Fingers Crossed
geposted Wed 20 Mar 19 @ 11:02 pm
Routine plugin and padpage surpasses serato's flip, only thing is it's pc only.
geposted Wed 20 Mar 19 @ 11:09 pm
Great...Will give it a go...Thanx
geposted Thu 21 Mar 19 @ 9:56 am
