Hi.
I have a folder of UK No. 1s using the following format; Year_Month_Date, e.g.1954_11_05, to list them in chronological order. Using the same example 1954_11_26 is the correct chronological order, i.e.below, 1954_11_05 in the normal folder/file structure of the pc. However it is inverted within Virtual DJ!
Before you tell me that I can turn them around by clicking on the top of the "Track" field you need to understand that the years are in the correct order but the months within the year are the wrong way.
Help!
Help!
geposted Sat 16 Mar 19 @ 5:34 pm
