Did a gig last night at a bar and they set there volume to 40% which is pretty low but for some reason i had a couple weird issues.
My volumes from both decks would play even if the sliders were all the way down or if the crossfader was all the way over it didnt matter. I basically had to just press pause in order for nobody to hear that track
Also it didnt matter how high i put the slider volume the volume stayed the same.
I basically had no control over my sound.... has this happened to anyone before???
geposted Sun 31 Mar 19 @ 5:39 pm
Are we supposed to just guess what equipment you were using?
geposted Sun 31 Mar 19 @ 6:56 pm
