Topic: DDJ SX2
Hi everyone,
I had my first gig of the year last Saturday. I plugged in my Controller and ran Virtual DJ I usually get a popup saying do I wish to use this controller that did not happen went to start a song sound was coming out of laptop speakers, I had to change the outputs in Virtual DJ to get the sound out of my speakers I was not sure what to choose as I only use faders 2 & 3 can this be fixed so that it does it every time I plug it in?
geposted Mon 01 Apr 19 @ 12:52 pm
It's only supposed to ask that the first time you plug it in
After that you should switch between different controller audio configs in the audio settings screen
For most controller it will be 2 clicks
1. Click the button named after the controller you want to use for audio output (there will usually be a button for each connected controller if you have more than one)
2. Click apply
If you use a setup that is more complicated than the default setup for the controller, you can save the config on the bottom of the audio config screen, and recall it when you need it
