I have a problem with virtual dj on my MacBook.
Whatever setting I use my waveforms are always shown in grey color, scratch waveforms are not visible.
I use the latest version of Virtual DJ, runs on a MacBook Pro 15 mid 2012.
What could be causing this?
geposted Wed 03 Apr 19 @ 1:42 pm
Which skin are you using?
geposted Wed 03 Apr 19 @ 8:17 pm
Default skin
geposted Thu 04 Apr 19 @ 10:11 am
No scratch wave sounds like the issue I had a while back (3291) with a low quality video card not going over texture bigger 2048 pixels.(fixed 3311) Although that machine never showed coloured song_pos waves with v8.
Details about your video card/chip and your screen resolution will help (try a lower resolution, that was a temp fix for me)
geposted Thu 04 Apr 19 @ 11:53 am
I am running on macbook pro mid 2012 (15 inch) with a seperate GPU so should more then capable enough
geposted Thu 04 Apr 19 @ 4:45 pm
Experimental skin engine on or off? Either way, have you tried switching it?
It really helps more if you give plenty of detail, instead of us having to ask.
geposted Thu 04 Apr 19 @ 4:48 pm
Hi,
Is this resolved? I'm having the same issue with a MacBook Pro mid 2015 (i7 quad core, 2,8GHz, 16GB memory, AMD Radeon R9 M370X 2GB and Intel IRIS Pro 1,5GB) . Already made an official ticket but no solution yet. So you can well imagine I'm interested if you found a solution...
Peter
Peter
geposted Sat 25 Jan 20 @ 5:31 pm
I found the root cause for this(at least in my configuration):
My drive was formatted case sensitive. After formatting it case insensitive virtual DJ works fine again. No more grey and missing waveforms for me
geposted Mon 27 Jan 20 @ 10:12 pm
