I launch VDJ64 and get the message about update. I applied it and nothing
launch debug mode :
Exception levée à 0x0000000000000000 dans virtualdj8_64.exe : 0xC0000005 : Violation d'accès lors de l'exécution à l'emplacement 0x0000000000000000.
which translate something like that
Exception raised at 0x0000000000000000 in virtualdj8_64.exe : 0xC0000005 : Access violation executing location 0x0000000000000000.
in thread 0x24C0 thread vbvmpins_asiodriver64.dll
ok VDJ64 v4787 does not handle some exceptions anymore ? was working before... message no soundcard but was not crashing
remove the setting.xml
this time it launch reconfigure without the missing/faulty 64bit asio...
... really can't share settings between 32bit version and 64bit version anymore
other thing, still only 1 video can be display.... and this is not a standard one but the only png based transparent mkv one
no other flv, mpeg, avi, mp4, mov, wmv, mkv... is show
CDG karaoke, transitions, overlays, visualizations, shaders, all work fine only no video
VirtualDJ8_64 is still the only one video software not being able to show any video LOL
yes, system is pretty old but videos are much more older and show using any other 64 bit software for lots of years
DirectX Version: DirectX 12
... physical display Intel :
DDI Version: 10
Feature Levels: 10_0,9_1
Driver Model: WDDM 1.1
Graphics Preemption: DMA
Compute Preemption: DMA
Miracast: Not Supported
Hybrid Graphics GPU: Not Applicable
Power P-states: Not Applicable
Rank Of Driver: 00EC2001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_B ModeWMV9_C ModeVC1_B ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeMPEG2_MOCOMP DXVA2_ModeWMV9_MoComp DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_MoComp DXVA2_ModeVC1_IDCT
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 1
MPO Caps: Not Supported
MPO Stretch: Not Supported
MPO Media Hints: Not Supported
MPO Formats: Not Supported
PanelFitter Caps: Not Supported
PanelFitter Stretch: Not Supported
and virtual dispay:
DDI Version: 12
Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 1.3
Hybrid Graphics GPU: Not Supported
Power P-states: Not Supported
Virtualization: Not Supported
Block List: No Blocks
Rank Of Driver: 00FF0000
Video Accel: Unknown
DXVA2 Modes: Unknown
Deinterlace Caps: n/a
D3D9 Overlay: Unknown
DXVA-HD: Unknown
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 0
launch debug mode :
DDI Version: 10
DXVA-HD: Supported
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 1
and virtual dispay:
DDI Version: 12
DXVA-HD: Unknown
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 0
geposted Wed 10 Apr 19 @ 9:07 am
If your ASIO driver is crashing, then not much vdj can do about this unfortunately.
geposted Wed 10 Apr 19 @ 10:24 am
Yes, it seems ASIO 64bit version of VAIO3 is not implemented yet in voicemeeter... not a real problem as it's a beta too
Previous version of virtualdj64 was handling this by desactivating the faulty config entry with a notification "no audio" which is really nice !! where the new one simply crashes
CrashGuard dialog raise and disapear so quickly i didn't notice it at first
geposted Wed 10 Apr 19 @ 11:47 am
Nothing was changed on vdj side, so must be random when the asio driver crashes and when it just fails.
geposted Wed 10 Apr 19 @ 1:10 pm
